Hp envy m6 dead
    Re: Hp envy m6 dead
    Check PU4-LM393 working or not. What is the voltage on both sides of DK1 or KBC pin 110??
      Re: Hp envy m6 dead
      What is the voltage on DK1 both sides or pin110 of KBC?? PU4(LM393) working??
        Re: Hp envy m6 dead
        Pu4 not working, all pins as 0v, kbc pin110 =0v
        I think kbc need 3v Alw to function?
          Re: Hp envy m6 dead
          SIO need +3VALW_EC to pin 9 22 ect since your 3/5 Regulatory is not working no power on SIO
            Re: Hp envy m6 dead
            Pq105 pin4=9v . I think i need 10v-30v for the the N channel mosfet to switch normal?
              Re: Hp envy m6 dead
              For the moment leave it Concentrate on your TPS51225C what is the resistance to GND pin 3 13
                Re: Hp envy m6 dead
                Thans for concern, i pull pu301 earlier and pin12 still give 9v in the absence of pu301.
                Ill measure the pin3 &13 resistance to GND and feed you back thanks
                  Re: Hp envy m6 dead
                  You mean you apllied power to mb while Tps51125C was removed from mb?? In that case there will be expensive damage to the mb. Might not be possible to repair.
                    Re: Hp envy m6 dead
                    Resistance to GND pin3=01.71, pin13=07.40 respectivly
                      Re: Hp envy m6 dead
                      You didnt answered this??
                        Re: Hp envy m6 dead
                        yes i did bro and vin still 9v
                          Re: Hp envy m6 dead
                          Getting 19V VIN doesnt matter if there are other failed components and there will be many such components as you did the mistake. It'll require very good skill and experience to find out what are those components. Good luck bro.
