HP Notebook - 15-ay019ca
    BDL50 LA-D702P REV 1.0
    it powers on for 4 seconds and then off, with no display
    i thought of power switch and bios but none worked
    Re: HP Notebook - 15-ay019ca
    What is the resistance to GND Bios pin8, what voltage is missing on the coils when you power the MB
      i have 19v, 3.14v near battery charger, 3.2v on power switch, all other volts are missing
        the resistance to GND Bios pin8 = 10.6 ohm
          The resistance is very low, try to find why.
          Become a Badcaps supporter
          Thanks to all supporters.​
            Check SIO pin 110 75 37 112 is the +3/+5 VALW line is ok ?
              pin 110 75 37 112 are all 3.2v
                +3/+5 VALW line is ok ?and EC_RSMRST# before you press the power button after you press the power button Voltage?
                  With this resistance, chances of pch being bad is very high.
