Hi, I have an 820-3787 Macbook logic board taken from a 15" Late 2013 Retina A1398 Macbook Pro.
Dim image appears on screen without backlight. Image can be seen by shining bright light through back side of LCD's Apple logo or via external display.
Visually inspected both sides of board for any signs of liquid damage but there did not appear to be any nor were there any signs of damage around backlight circuitry. None of the moisture/liquid indicators were red either.
0V is present at pin 1 of the LCD connector (PPVOUT_S0_LCDBKLT) while running with LCD plugged in. Checking resistance to GND revealed 30 ohms. I assume this is shorted to GND.
Tested with known good working LCD with same results, no backlight present (0V, 30ohm to GND). Also tested without any LCD connected with similar results.
Does this sound like a bad LCD connector or more of a backlight circuit issue? Don't want to inject voltage and blow anything up
Boardview and schematics are attached.
