Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Tablets, and Mobile Devices
Thread Tools Display Modes
Old 03-10-2021, 06:44 PM   #1
bakre
City & State: Nederland
My Country: Zwolle
Line Voltage: 220VAC 50Hz
I'm a: Knowledge Seeker
Default Lenovo X250 not charging
Hello
I have an Lenovo x250 laptop that is not charging, but when I change the volt from 20v to 18v is start charging normally, do any one have an idea?
the bios is updated to last version, i have also change the battery but the same problem also.
I have test the id charger is good and replace ic charger the same problem and replace the SMC the same problem.
bakre is offline   Reply With Quote
Old 03-10-2021, 11:14 PM   #2
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
I'm a: Professional Tech
Default Re: Lenovo X250 not charging
Check AD_ID voltage when powered by 20V/18V and observe the difference.
mcplslg123 is offline   Reply With Quote
Old 03-11-2021, 03:54 AM   #3
bakre
My Country: Zwolle
yes it is change to 1,69v with 18 volt but with 20 volt it give 1,44volt.
i try to replace the resistor to make the id volt 1,69v when plug 20 volt but it remain not charging the same problem, the problem it is not the id charger, it is something else.
but when power it with 18 volt the 3,3v it rise to 3,7v, and when i power it with 20v the 3,3v it remain 3,3v.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
