Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 04-08-2021, 02:16 AM   #1
samtron786
City & State: NRW
My Country: germany
I'm a: Knowledge Seeker
Default Solar Controller MPPT 100A
I have ordered such a solar controller MPPT 100A
my problem that goes off every now and then
At the beginning it worked very well and now the battery is 12.8 V sometime will be switched off
many thanks
https://de.aliexpress.com/item/10050...8%2315607%2390
samtron786 is offline   Reply With Quote
Old 04-08-2021, 11:40 AM   #2
redwire
City & State: Alberta
My Country: Canada
Default Re: Solar Controller MPPT 100A
I would check the programming and see if it did not get scrambled or corrupted. Check that the correct battery type is programmed - lead-acid, lithium, LiPO4, and 12/24V.
If the programming is good, then look for a bad connection in your wiring, or inside there could be a cracked/bad solder joint. If you are too rough screwing in the terminal blocks, you can break the connection on the PCB.
I could not find a good manual for the charger controller. It seems to shut off if it is overheating, over or under-current. Than might be causing it to stop.
Or you just have too small a solar panel, cloudy days and the battery is going low.
redwire is offline   Reply With Quote
Old 04-10-2021, 03:26 AM   #3
samtron786
City & State: NRW
My Country: germany
OK thank you
I'll test it
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
