Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 04-08-2021, 11:25 AM   #1
samtron786
City & State: NRW
My Country: germany
I'm a: Knowledge Seeker
Default Telefunken D32F289M4CWI no picture Only the sound
The problem with the Telefunken LCD TV "D32F289M4CWI" is that since switching from one program to the other, the picture is gone and only the sound can be heard (screen remains black).
The TV is about 2 years old.
Would still be grateful for help
many thanks
samtron786 is offline   Reply With Quote
Old 04-08-2021, 12:29 PM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Telefunken D32F289M4CWI no picture Only the sound
(screen remains black) If you mean there's no backlight, check the screen by shining a flashlight on it, maybe at an angle, see if there's a picture or hit menu see if there's a display at all with flashlight.
__________________
(Signature) One of the first and least expensive things you can do when you have an issue is take the powerboard out of the tv, flip it over and look the solder joints over with a magnifying glass if needed, add a little flux to make the solder flow well and add solder to any joints that look even a little suspect. You can practice on a scrap pcb board if needed, careful not to bridge any joints, and always let the board sit for quite a while or discharge the big caps with an appropriate resister before working on it (safety first) to try to keep from getting shocked, it doesn't take 1000 volts to KILL, a lot less can kill, so be careful, it's only a tv.
nomoresonys is online now   Reply With Quote
Old 04-09-2021, 01:34 AM   #3
samtron786
City & State: NRW
My Country: germany
Yes I can take a picture with low light
Old 04-10-2021, 03:18 AM   #4
samtron786
City & State: NRW
My Country: germany
I tested the LED again, they are all fine
Old 04-10-2021, 03:45 AM   #5
nomoresonys
My Country: U.S.
Read and comprehend/translate post #2.
Old 04-11-2021, 01:53 AM   #6
samtron786
City & State: NRW
My Country: germany
Yes I only have sound, no picture and no obstruction lighting
Old 04-11-2021, 02:27 AM   #7
nomoresonys
My Country: U.S.
Check the fuse on the tcon board, meter 20 vdc black - probe on metal chassis ground, red + probe on each side of fuse see if it's about 12 volts on each side.
Old 04-12-2021, 12:12 PM   #8
samtron786
City & State: NRW
My Country: germany
Yes I have 12.20V in both sides
a question, is there a list of VAVDD how much current has ??
the diode has 3.33V
many thanks
Old 04-12-2021, 03:29 PM   #9
nomoresonys
My Country: U.S.
Some simple voltage testing there: https://www.youtube.com/watch?v=t11FEuu1oWU
Old 04-12-2021, 04:07 PM   #10
samtron786
City & State: NRW
My Country: germany
gives wiring diagram of this TV ??
or do I have to look for wiring diagram from T-Con?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
