Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 08-10-2021, 08:56 AM   #1
braxton
Default Black and Decker 40V Lithium weed trimmer PCB board damage
I have a Dewalt / Black and Decker 40V trimmer model LST136 Type-1.
It stopped working. Trimmer motor tests fine. I opened it up to find that the controller board had a blown component at position Q5. It also looks like a similar component at D6 has a bulging area. These two mosfets? are attached to a heat sink. The D6 component looks to be a MBR20100CTP rectifier. The Q5 component blew apart, so its difficult to read the label. I am hoping to get help identifying the Q5 component. Pictures are attached.
In the photos, the heatsink and the Q5 component have already been removed from the board. One of the three legs broke off of the Q5 component.
The last 2 pics are of the component I need help identifying.
Last edited by braxton; 08-10-2021 at 09:01 AM.. Reason: corrections and additions
braxton is offline   Reply With Quote
Old 08-10-2021, 09:11 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Black and Decker 40V Lithium weed trimmer PCB board damage
100v is too low for a schottky diode - 250v atleast.
ideally 10x the running voltage!
stj is offline   Reply With Quote
Old 08-10-2021, 09:17 AM   #3
braxton
Thanks. I will keep that in mind when ordering the D6 component.
Any idea what Q5 is?
I am attaching two more photos of the board
File Type: jpg 2480832F-411E-4A38-AA7C-22E08BA39510.jpg (220.2 KB, 26 views)
File Type: jpg E1CDF579-FA6B-4CBF-A07E-5133FB5BDD82.jpg (218.9 KB, 25 views)
Old 08-10-2021, 05:03 PM   #4
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
Be careful with protection boards when repairing them make sure that the battery are not fully charged if necessary run them down to 3.2 volt and be ready to remove it from the tool or the charger if something goes horrible wrong
I have repair Ryobi battery packs sometimes you can repair them sometimes not
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 08-12-2021, 06:59 AM   #5
SluggerB
City & State: Philadelphia, PA
My Country: US
Try and find someone who owns one (or buy a new one), open it up, identify the part, and then return it?
SluggerB is offline   Reply With Quote
Old 08-12-2021, 08:13 AM   #6
sam_sam_sam
My Country: USA
I just noticed that this battery pack is 40 volts which I do not have
Just be aware of this if this is an older battery pack the controller board of a new one might not be the same as one you have
Old 08-12-2021, 08:51 AM   #7
braxton
Here are photos of the trimmer with the model number.
The board is from inside the handle part.
The board is not from the battery itself.
File Type: jpg 9F44E855-E929-4C30-BD2A-341B0B65F779.jpg (913.3 KB, 11 views)
File Type: jpg EBBA2C33-99F5-477A-915C-34DEEC8D9FBC.jpg (255.3 KB, 12 views)
Old 08-12-2021, 09:46 AM   #8
braxton
Based on a closer look at the blown chip, it looks like it is an Infineon IRL3705Z mosfet.
Digikey lists it as obsolete.
Can anyone help out finding this part or an equivalent?
Thanks.
Old 08-12-2021, 11:12 AM   #9
R_J
City & State: ☻
My Country: Canada
Thanks.
If that is the correct mosfet...
Digikey IRL3705ZPBF-ND direct replacement, in stock
R_J is online now   Reply With Quote
Old 08-12-2021, 02:21 PM   #10
braxton
Thanks!
Ordered a few of those and the MBR20200CTP (200V instead of 100V)
Hopefully that will get the trimmer working again...
Old 08-12-2021, 03:03 PM   #11
R_J
City & State: ☻
My Country: Canada
Check the gate drive circuit resistor (R24) to make sure it is not open, When the mosfet shorted, many times it also takes out the drive ic, that sot23-5, best to get it's number before it is also unreadable.
Old 08-12-2021, 05:19 PM   #12
sam_sam_sam
My Country: USA
This means that the charger has the protection board and the battery has no protection board might not even have a protection fuse in it
When you test this board be careful and be ready to disconnect the battery very quickly if something goes horrible wrong
Old 08-12-2021, 09:35 PM   #13
braxton
R24 resistor has 753 written on it and tests at 75.5 Kohm
Old 08-12-2021, 09:45 PM   #14
braxton
The sot23-5 chip is hard to read but it looks like GX3mD maybe?
File Type: jpg 25A9EA35-CB34-4AFC-A0DB-D559BE8E2257.jpg (247.8 KB, 14 views)
Old 08-13-2021, 05:32 PM   #15
braxton
Replacing the 2 chips had no effect. Still dead.
What about this component (largest chip in the corner) in the attached photo?
File Type: jpg 51BFC3C0-D819-4A42-A6B2-3BD2323E3856.jpg (366.8 KB, 12 views)
Old 08-13-2021, 08:15 PM   #16
stj
stj's Avatar
the "dale" part is a resistor - it should look like a short circuit.
clean the board with alcahol - it's hard to see the parts clearly.
Old 08-13-2021, 09:49 PM   #17
R_J
City & State: ☻
My Country: Canada
After a closer look R24 is likely the resistor between the mosfet source pin (Dale resistor) and the CS pin of the ic, and not the gate drive resistor. Check that the resistors between the gate and the ic are ok.
Old 08-14-2021, 09:06 AM   #18
braxton
I tried to take better photos of the board.
I also measured all of the resistors on the board and all seem to give an ohms reading (Highest was 100K and none seem to be open as far as I can tell).
File Type: jpg 5CE430EC-0FE2-474B-BCFC-76DCBAE3EB42.jpg (290.7 KB, 10 views)
File Type: jpg FA05D39C-D4D1-4D22-B334-188826AE59E6.jpg (325.0 KB, 10 views)
File Type: jpg 20271F4D-A091-4551-AD3B-75BA54B090D8.jpg (420.2 KB, 11 views)
Old 08-14-2021, 10:27 AM   #19
petehall347
City & State: worcester
My Country: United Kingdom
what about these solder joints ?
File Type: png Screenshot from 2021-08-14 17-26-41.png (167.7 KB, 15 views)
petehall347 is online now   Reply With Quote
Old 08-14-2021, 02:58 PM   #20
sam_sam_sam
My Country: USA
Quote:
I agree with you that these connections do not look very good
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
