Sapphire RX570 Nitro 4GB Repair Help
  • spiderspore
    • Jan 2022
    • 47
    • Ireland
    i have a Sapphire RX570 Nitro 4GB it keeps causing the pc to reboot it does sometimes load windows and i manged to play gta5 on it for about 15mins then reboots again
    i did a few checks and found that vcore memory and memory controller turns off and back on again i thought it might be a faulty vrm controller so i replaced it but same thing happens never came across this kind of fault before anyone know where i should begin from here
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Sapphire RX570 Nitro 4GB Repair Help
    This sort of problem can be due to a faulty RAM chip/chips on the video card
    This will show you how to test it
    https://www.youtube.com/watch?v=a4QUkoBvxuY
    Follow me on YouTube
    Learn Electronics Repair
    • spiderspore
      • Jan 2022
      • 47
      • Ireland
      thx alot for this info
      i downloaded all the stuff im trying to use disk genius to setup the drive but when i right click on the drive quick partition is greyed out and f6 on the keyboard doesn't work, its connected using sata on the motherboard but on my usb drive i have connected it isn't greyed out u know why that is
      • spiderspore
        • Jan 2022
        • 47
        • Ireland
        i managed to get that setup and working i ran the test and got a pass
        • Bozog
          • Jan 2022
          • 125
          This maybe useful...
          Originally posted by DynaxSC
          It could be that tserver does not detect a memory error, when the memory is only "somewhat" broken, so that it fails on higher frequencies only.
          There is a way to let tserver test on higher frequencies -> You may try the hint from DrasticRepairs at the end of the thread:
          https://www.badcaps.net/forum/showthread.php?t=101715
          • spiderspore
            • Jan 2022
            • 47
            • Ireland
            thanks again for the help
            got the mem test working got to 1362.5mhz and still a pass anything higher it starts to run the test then the computer reboots, happens every time so might be difficult to identify the faulty module
            • foshland
              • Jan 2017
              • 122
              • Spain
              Same problem here with a rx470 8gb, dont know what else to do (i mean running on supposed default ram clocks, not more)
              • DynaxSC
                • Apr 2021
                • 451
                • Poland
                Hi, maybe it is something with powersupply, so the power/voltage supervisor chip thinks that the power usage is out of range or some supply voltage is out of range. Maybe not all vrm phases are working but are not shorted ??? Don't know this card, but on Nvidia cards the monitoring is done often by a chip called INA3221. It measures several voltages and also the current for several supply lines (via a serial low ohm resistance). Could be also temperature monitoring.
                • spiderspore
                  • Jan 2022
                  • 47
                  • Ireland
                  anyone know what the voltage supervisor chip on this card is i cant find out what does it
                  • spiderspore
                    • Jan 2022
                    • 47
                    • Ireland
                    hit a dead end with this, couldnt find what the voltage supervisor chip is on this card, so i replaced both GS7256 buck controllers on memory and memory controller in case they weren't working properly but still no difference dont know what to do from here
                    • spiderspore
                      • Jan 2022
                      • 47
                      • Ireland
                      anyone have any ideas on where to go from here?
                      • SiO2
                        • Apr 2022
                        • 24
                        Recently had a 480 and a 580 with similar symptoms. After reducing the core and memory clocks by ~50-60 MHz, they worked "fine".
                        Gave up on trying to fix this and assumed some form of degradation.
                        • spiderspore
                          • Jan 2022
                          • 47
                          • Ireland
                          it isnt stable enough in windows to reduce clocks it reboots as soon as i login
                          • spiderspore
                            • Jan 2022
                            • 47
                            • Ireland
                            made some progress with this card, solved the rebooting problem by replacing the vrm controller and the pc stayed on for 12 hours without rebooting
                            card works as primary gpu for normal use no artifacts cant install drivers shows as code43 in device manager
                            in gpu-z it shows gpu clock as 0 MHZ
                            • spiderspore
                              • Jan 2022
                              • 47
                              • Ireland
                              i tried flashing a new bios but amdvbflashwin doesn't detect it only the onboard graphics is detected
                              • spiderspore
                                • Jan 2022
                                • 47
                                • Ireland
                                i ran another ram test with the dmgg.py script and got no bad chips
                                if its not the ram what are the other causes of code43
                                • didi79
                                  • May 2021
                                  • 80
                                  • BE
                                  Flash unpowered with something like a CH341A programmer?
                                  • spiderspore
                                    • Jan 2022
                                    • 47
                                    • Ireland
                                    hopefully that works. i ordered one already just waiting for it to arrive
                                      ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                      This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-12-2024, 03:28 PM
                                      ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                      This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 04:10 AM
                                      Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i5-11400H, 8GB, 512GB SSD, NVIDIA RTX 3050Ti,...
                                      09-07-2024, 03:10 AM
