Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 07-29-2021, 08:49 AM   #1
taxxin
taxxin's Avatar
City & State: bangkok
My Country: thailand
Line Voltage: 240v
I'm a: Hardcore Geek
Default ASUS STRIX RX570 4GB - CODE 43 Error
Dear All,
I have an interesting one today, I have got a batch of old mining cards which are in for repair.
Card 1: No power to all rails, opened up and saw that the GPU chip has been popcorned. Someone had hit it with their chinese hot air station and popped ettt (NEW GPU CHIP and POWER WORK)
Card 2: All power rails are present, the corner of the GPU die is chipped. This is probably no good too. (NEW GPU CHIP)
Card 3: Looked good booted up with bios and windows safe mode works great. but would crash out when windows loaded up, Ive tested over 10 types of bios all for this model with ELPIDA ram chips. None of them can get past a driver download, some will not display memory details in GPUZ. I dont know what to do with this, ive changed out the BIOS chip and flashed several kinds of bios with no luck.
Card 4: No power to all rails, I changed the 0.9v rail buck converter chip and all power rails are now present, lights up but fans dont spin, I found that the BIOS chip had been taken off, I have replaced the BIOS chip and flashed a BIOS for the ELPIDA chips, it doesnt display anything but chip does get warm feeling from the back side.
As a secondary card it is recognised by windows, see the screen shot. in devmgr it shows code 43. In HWINFO there are no memory errors counted:0 but i guess its not even working??
What shall I do next? Im stuck here at the same stage as the other RX560 card that I have. What would be my next course of action?
taxxin is offline   Reply With Quote
Old 07-29-2021, 10:43 AM   #2
taxxin
taxxin's Avatar
Line Voltage: 240v
Default Re: ASUS STRIX RX570 4GB - CODE 43 Error
So i just realized i attached screenshots that are useless in the main post.
Old 07-30-2021, 08:44 AM   #3
taxxin
taxxin's Avatar
Line Voltage: 240v
Photos of the cards, mostly identical except the ram chips vary some are SK HYNIX and others are ELPIDA, ALSO some dont have RGB for the fan body.
Old 08-04-2021, 07:32 AM   #4
Fulllock
City & State: Tartu
My Country: Estonia
I am not familiar with HWINFO memory error test(?) but recently I swapped RX570 4G mem to 8G, flashed the BIOS and the card first had the same sympthoms - no GPU freq in GPU-Z and error43. I used this script to test the memory IC's and as predicted, one IC had a bad solder joint.
Fulllock is offline   Reply With Quote
Old 08-05-2021, 07:34 AM   #5
taxxin
taxxin's Avatar
Line Voltage: 240v
Thank you very much, this is very handy info, I am in the process of creating a GPU test computer, the AMDTEST file is massive and its hard on my HDDS.
I think that this might be the case with a few of my cards, because it has had a hard past life as a mining GPU I would not be surprised if one of the memory dram chips are faulty.
Old 01-24-2022, 04:22 AM   #6
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
guys can u share that script? i cannot find it
ktmmotocross is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
