Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 03-30-2020, 01:30 PM   #1
mnaty
City & State: augusta
My Country: United States
I'm a: Knowledge Seeker
Default Sony un50h5500 washed out image
Picture of tv is washed out, but all features are working and visable. There may be a slight blur to the text, but not sure that's just a result of the washed out effect, or a sign of something more, as i ordered a t-con board replacement from shop Jimmy and got the exact same results.
From what I've gleaned from the web, this issue is usually due to a bad cmi ic chip on the tcon, so either I got a bad board from shop Jimmy with the exact same issue or there is another possible cause of this issue that im missing.
Any guidance is appreciated.
mnaty is offline   Reply With Quote
Old 03-30-2020, 01:39 PM   #2
neilc6
City & State: BC
My Country: Canada
Default Re: Sony un50h5500 washed out image
I've done AS15 replacements repeatedly on LCD TV screens with washed out images with no change and my conclusion that the issue had to be the panel and not the tcon. Have you tried powering up the tv with only one side from the tcon connected at a time?
neilc6 is offline   Reply With Quote
Old 03-30-2020, 02:08 PM   #3
mnaty
Thx for responding. I tested with alternating discommect of the tcon ribbon cables and same washed out result on each side. 100% of screen image is visable, but dull/faded display that has a white washed haze.
Old 03-30-2020, 02:26 PM   #4
neilc6
City & State: BC
My Country: Canada
I've also ordered used tcons that were obviously bad as well. Companies that take returns most likely don't test them so a bad tcon can be resold repeatedly.
Old 03-30-2020, 02:35 PM   #5
mnaty
Anybody got a schematic/service manual for this TV or tcon so that i can rule out defective part?
Old 03-30-2020, 02:51 PM   #6
mnaty
With the fact that the issue is the same on both sides when alternating cables, does this make it more likely that the issue is a defective part order was received?
Old 03-30-2020, 02:58 PM   #7
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Can we see a decent photo of the tcon?
diif is offline   Reply With Quote
Old 03-30-2020, 03:13 PM   #8
mnaty
Here ya go.
Old 03-30-2020, 05:36 PM   #9
nomoresonys
City & State: midwest
My Country: U.S.
Sticker numbers don't match, wonder if maybe it's not compatible?
nomoresonys is offline   Reply With Quote
Old 03-31-2020, 02:23 PM   #10
notallbad
City & State: UK
My Country: UK
I've fallen into this trap before, buying a t-con matching the board part numbers only to find that it still doesn't work.
You need to ensure the T-con came from the same panel as your tv too! and just matching the t-con board is defo a no-no.
Problem is, most ebay sellers don't make a note of the panel part number the t-con came from so sometimes just matching the TV model number and t-con board number is not enough.
So don't write off that TV just yet.
notallbad is offline   Reply With Quote
Old 03-31-2020, 03:53 PM   #11
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
The PCBA numbers on the barcode sticker do not matched.
SJ PCBA is 32746A, your is 30065A, you may want to verify that with SJ.
https://www.shopjimmy.com/samsung-bn...con-board.htm#
BTW, going by the model number you provide, TV is SAMSUNG, not SONY.
__________________
budm is online now   Reply With Quote
Old 04-02-2020, 08:48 AM   #12
mnaty
You are correct on both accounts. Odd that it works exactly the same on both board, but i did in fact order the wrong part. Time to order another, although I may try to swap the cmi pwr driver ic to see if it fixes the issue. If not then I'll order the correct part.
Also, not sure why I got sony stuck in my head, it's definitely a samsung. Thx for getting me back on track.
Old 04-02-2020, 08:50 AM   #13
mnaty
Thx, you are correct. I'm going to sort it out and see if it can still be saved.
Old 04-03-2020, 12:02 PM   #14
mnaty
Ok, so I swapped some parts from sj board that was a non match with original board.
Swapped cm608 ic and p12 voltage reg. (voltage on regulator is 3.3v on left side and right side is 1.2 which I thought was vr output and was also supposed to be 3.3v)
No change, but ive now noticed that the cm603 ic which is the smaller ic on the right hand side is extremely hot. However, not sure if this ic is interchangeable. Anyone know for sure, as i could find no data sheets for any components.
Old 04-03-2020, 02:01 PM   #15
nomoresonys
My Country: U.S.
The tcons are only a few bucks: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
Old 04-03-2020, 02:16 PM   #16
mnaty
Correct, but you never know if you're getting a fully functioning one when oreldering used. And I already wasted 30 on the shopjimmy board. I already have one on order, but figured I would try repairing since I have the required tools and skill. Just need schematics. Right to repair needs to hurry up
Quote:
Old 04-04-2020, 03:11 AM   #17
nomoresonys
My Country: U.S.
Ouch, you could have sent the 30 dollar board back and gotten 4 or 5 from ebay, I've had good luck on ebay like 95 percent, when the cost is 1/5 I'm buying, shopjimmy stands by their stuff but so do many honest people on ebay. Not that I like ebay's greediness with recent policy changes but that's another story.
Old 04-07-2020, 11:30 PM   #18
mnaty
So just an update...
Cm603 was almost burning hot to the touch, so I pulled ic chip from one of the non matching boards for swap. After completing reinstall of the swap chip it was still hot to touch but I noticed that the color settings were now slightly better, so I fiddled with controls and options cycling through to see if it could be made right
After 10 minutes of fn with settings, the picture snapped to and the overheat of cm603 ceased and is now cool to the touch while in operation.
Ultimately I swapped 608 and 603. 603 seems to be inline with short but maybe not the exact cause as overheat persisted for a time after swap.
It was reported to me that tv had been wiped tv with a damp cloth prior to screen bleach affliction. Some signs of potential water penetration behind filter layers near edges were visible. Any chance that if water got on the cof tabs it would need to be baked off with heat before short would disappear. (Just curious)
In reflection, I think 608 was dead and overheat on 603 did not occur until 608 was swapped. However replace of 603 was necessary to get whatever bad juju that still remained worked out. Time will tell if it's a permanent fix.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
