Lenovo X1carbon 1gen need help with whitelist remove
  • Serega_rid
    • Mar 2020
    • 4
    • Kazakhstan
    Hello to all, need help with editing bios to remove whitelist and works with miniPCI cards. May upload dump if need.
  • Aditya11ttt
    Adi
    • Feb 2019
    • 177
    • India
    Re: Lenovo X1carbon 1gen need help with whitelist remove
    can u share dump once ?
    u need that any other wifi card to work in your system ?
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Post here bios dump or i need error photo.
      • Serega_rid
        • Mar 2020
        • 4
        • Kazakhstan
        From start i byu this device without any wlan card . My error is to use standart minipci card in wwan slot, i edit bios and startup error with whitelist is successfuly passed but adapter not seen in device manager, than i think in other direction (schematic of mainboard very helps me) and use usb wlan module from poor chinese tablet (rt8188) by wiring it from cn12 usb and 3.3 / GND lines . In the end wifi works good without original wifi card . bios dump.
        • Serega_rid
          • Mar 2020
          • 4
          • Kazakhstan
          that works normal, interested mechanism of wwan lock on hardware level or i not understand right?
          • xsd611
            Lenovo X270 Bios - remove Whitelist
            by xsd611
            ​Hello, this is a BIOS file for the Lenovo X270 laptop, read out through a CH341 programmer. I located error 1802 in the PE32 module. This is a detection for the network card's whitelist. How can I bypass or remove the whitelist check? My skills are limited, and I have tried many times but ended up with a black screen. How can I normally bypass this whitelist check? Please help me edit this BIOS file, thank you. It would be great if you could provide illustrations to guide me. Thank you very much!...
            Yesterday, 09:13 PM
          • fasda1984
            remove wifi whitelist from lenovo T440
            by fasda1984
            hello can you please remove wifi whitelist from lenovo T440 . Thank you in advance...
            07-12-2024, 01:59 AM
          • houcine4500
            plz someone remove whitelist from lenovo t540p
            by houcine4500
            plz someone remove whitelist from lenovo t540p...
            03-09-2023, 03:02 PM
          • techcraze
            Lenovo 15ARH05 LCD whitelist removal request (Yes. display whitelists....)
            by techcraze
            Long story short. i am building a fully custom car radio. and want to use a extremely bright LCD.
            sadly the DGPU seems to be nonfunctional after i fixed the bios (fried voltage controller). so the Original HDMI port does not work.
            you can use a EDP TO HDMI adapter to add a HDMI port as replacement to the onboard EDP LCD connector,
            HOWEVER it turns out. lenovo enforces a LCD whitelist.
            this means you cannot upgrade the LCD despite matching EDP specs and voltages.
            If i connect a new screen directly to the system. only static shows....
            05-08-2025, 07:50 PM
          • Popel1083
            Lenovo IdeaPad U330p Read Bios than Bios Password Remove
            by Popel1083
            I want to remove the Bios Password of my Lenovo IdeaPad U330p with the Lenovo autopatcher. I have the CH341A Black and I'm using NeoProgrammer. The Programmer has an LED that indecates when it reads or writes the Chip. When I try to Connect my Programmer to the Bios Chip (Winbond 25Q64FVSIQ) the LED lights up even though I didn't click on Detect botton in NeoProgrammer. If i click on Detect the LED still remains on and NeoProgrammer says "IC not responding".
            SN: QB08570065
            MB: DA0LZ5MB8D0; REV: D; MODEL J31/N02
            08-06-2024, 05:52 PM
