I have two identical Asus rx480 GPU, both do not power up and display.
1st card I checked all around for a short, just after the chokes all caps are showing short to ground
2nd card I had in the motherboard to test and was showing the same symptoms so immediately removed and checked the same area for shorts and all caps short to ground. This time however three MOSFET were showing a short.
I got my rework station out to swap out the faulty MOSFET. While it was warming up I was going to mark up the faulty ones and the short was gone
I put both cards in the motherboard and the short appears on both the cards MOSFET and then goes after a while.
Any ideas on what is causing this, the shorted caps are there all the time should I just remove and check them all?
