I bought this laser module a few years ago and did not do anything with because I did not have a TTL module so it sat in project box to do something with at a later date
Well the later date has happened now
What I did to this module is disconnected the cooling fan and going to use with a fan temperature speed controller ( out of a surplus computer switching power supply )
Well now I have found a 15 watt TTL module that I just bought from AliExpress which I should have in a few weeks
Some time later when I have learned to use a laser engraver I going buy a 30 watt laser
I modify the engraver controller board because they left off some of the components for the laser power TTL output so I just took the TTL output from the Arduino Nano an put it to a 4N35 optic sensor to control the laser and ( or ) also a variable speed drill controller that I am either going to buy or make I have not decided which way I going to do this part ? ?
I still have to get some “V” slot rails because the engraver is to small for what I would like to do with it
The EBay seller that I am going to buy this stuff from they have to give the shipping cost before I make this order
I have done some testing with the software that I going to use for the engraving
The stepper motors which seems to work pretty good
Here is the link to the laser TTL controller
https://a.aliexpress.com/_d8iUPPV
