Remove_SMM... UEFI.
    Re: Remove_SMM... UEFI.
    Originally posted by alqotary
    ThinkPad T430
    Here you have point connection for SCL SDA from security eeprom L08
    I here from the internet that if you keep connected SCL & SDA together. And start the notebook with F1, you can bypass the password and change it.
    I never did this. So you have a risk.
    Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
      I know the away but I want try ThinkPad T430 Patch
        The pass will still be there on the L08 chip,no point patching the bios.
          I have decided not to provide any dump here because for me it's not clear what steps are performed with this dump. The steps from this thread did not work for the L560. I will leave the laptop locked as it is if the activation of the ATA security will also not help. Another idea is to buy a new motherboard. I don't like it but this gives me full control.
          Good luck for other users who want to learn by themselves.
            See post 7 and 9 https://www.badcaps.net/forum/showthread.php?t=84383
              Originally posted by SMDFlea View Post
              Thanks! I will have a look.
                You make a big confusion. It's about L560. Not about L540
                L560 it doesn't have EEPROM
                Many beginners make confusion beetwin SPI flash 25Xxxx and EEPROM's, and they short the BIOS chip.
                holu00
                I suggest you to leave HDD/SDD removed from your notebook. Start and check if you have password without HDD.
                If you have password patch the BIOS, run it, put back the original BIOS and check if password is gone. If it is, put back your HDD. If ask for password is clear that your HDD is password protected.
                Do you know to use UEFITool ?
                  holu00
                  Oh i guess you`re right, my bad .
                    please need patched file
                      try this file and valid with any key
                        Please can someone patch this one?
                          Let's try !
                            please patch it x270
                              Let's try !
                              Thanks, flashed this but 5 beeps and black screen.
                                I take a look to T490 BIOS. I find two LenovoTranslateService and two BootOptios, I compare and look the same.
                                Did someone try to patch all 4th of them?
                                  Another file if you want to test
                                    Thanks for your efforts in helping, it's much appreciated/
                                    One question, i've been studying previous modifications of the X1 Yoga and they all appear to have had the VSS2 Certificate store deleted, however the ones here which you patched when i open with UEFItool still show them there.
                                    I think this might be an issue
                                      Try this
                                        Please patch for this bios dump, think T460,
                                        Thank you very much.
                                          I need patch ThinkPad X1 Carbon 4th Gen please
