Asus K40AB
    Asus K40AB
    hi to all
    schematic needed for the model at the title.
    please help...
    when power button is pressed, led lights on, no fan initialization, no display.
    anyone knows whats the solution?
    thanks
    Re: Asus K40AB
    did you took out the mobo? did you check anything? reflow?
      Re: Asus K40AB
      Bottom cover removed. I cant figure out which coils are for valw.
      Im in the process of taking off the mobo right now. Found a guide to remove it.
      Pretty tough to remove, my first time to remove this kind of model
        Re: Asus K40AB
        Here.
          Re: Asus K40AB
          thanks
            Re: Asus K40AB
            yes, took out the mobo. did not attempt to reflow yet. will reflow if fan spins.
            5v 3.3v present
            cpu voltage present after power button
            gpu gets warm after pressing power button
            but fan does not spin
            no display, no beep
            also no rsmrst after pressing power button
