Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 05-27-2020, 04:09 AM   #1
axon18
City & State: Ovar
My Country: Portugal
I'm a: Knowledge Seeker
Default Lg 32lb5700 no power on led
Good Morning,
I have a TV that suddenly stopped showing pictures. After searching in the internet, i find that could be the LED tapes. I opened the TV and it really had a burnt and scorched tape led ... i replaces them all.
When I connected everything is the same.
Can you help me?
I attach the photos and measurements on and off.
Sorry my bad english.
axon18 is offline   Reply With Quote
Old 05-27-2020, 04:43 AM   #2
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Default Re: Lg 32lb5700 no power on led
You are missing a signal from the mainboard to turn the leds on. DRV_On should be approximately 3.5V
Disconnect the mainboard from the power supply and connect a 1K resistor from 3.5V to PWR_On and a second 1K resistor from 3.5V to DRV_ON
__________________
dick_barton is offline   Reply With Quote
Old 05-27-2020, 08:15 AM   #3
salarsat
City & State: abadan
My Country: iran
Hello
your board need to be reball CPU !!!!
do not tuch any thing !!!
salarsat is offline   Reply With Quote
Old 05-27-2020, 09:14 AM   #4
nomoresonys
City & State: midwest
My Country: U.S.
Quote:
Originally Posted by salarsat View Post
Hello
That's just a HUGE assumption.
__________________
1) https://www.youtube.com/watch?v=4F2J1Dkf4Is
HIGH VOLTAGE HAZARD demonstration. Video by Electronic Doberman.
NO LONGER CONTRIBUTING BECAUSE OF THE NO TIP POLICY.
nomoresonys is offline   Reply With Quote
Old 05-28-2020, 03:52 PM   #5
axon18
City & State: Ovar
Hello, i make what you said and the led poweer on, then i disconnectt the led and check 142vdc in led connector.
Old 05-29-2020, 01:56 AM   #6
dick_barton
My Country: Wales
So the backlight works when you tested using the resistors, yes?
Old 05-29-2020, 02:00 AM   #7
axon18
City & State: Ovar
Yes
Old 05-29-2020, 02:29 AM   #8
dick_barton
My Country: Wales
It looks like you have a mainboard problem not providing the signal and your leds are OK.
Can you follow the DRV_ON pin on the mainboard and see if it connects to a transistor/mosfet.
Old 05-29-2020, 02:47 AM   #9
yokoono
Or reflow to the processor.
yokoono is offline   Reply With Quote
Old 05-29-2020, 04:53 AM   #10
axon18
City & State: Ovar
After search i find that c701 is missing, there is olny the place with solder.
I attatch picure with the pin DRV_ON and the component that is missing.
And i don't know what is...i search the board but i can't find the manual..eax65610905
Old 05-29-2020, 05:17 AM   #11
dick_barton
My Country: Wales
Why would the smd capacitor C701 be missing? It does look as though it is. Was this TV working for you or do you have it for repair? Has the mainboard been replaced or worked on?
Old 05-29-2020, 05:36 AM   #12
axon18
City & State: Ovar
The television was working. It was on a living room sideboard and then I posted it on the wall. after that it worked a few hours.
It wasn't to fix. It won't pay off. Appliances are very expensive to repair here.
Can you tell me what componet i have tu buy tu put there.. to see if works.
Regards
Old 05-29-2020, 05:42 AM   #13
dick_barton
My Country: Wales
Unfortunately, I do not know what the component is.
Perhaps someone with an identical board could tell you but there would be no guarantee that that is the only problem. There also appears to be an smd resistor alongside that is not in circuit so it may be that they were never included in this version of the mainboard.
Old 05-29-2020, 05:55 AM   #14
nomoresonys
My Country: U.S.
That's where a MLLC capacitor would go, see all the others, look around tho, maybe this setup did not require that cap, there are many more places on that board that don't have those caps in place, see them, just because there's a place for one does not mean it was needed in this particular setup/configuration.
Old 05-29-2020, 07:35 AM   #15
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
That's definitely looks broken off, non filled pads have more rounded solder domes. I have an identical board here and have just pulled that capacitor, it's 10uf.
diif is online now   Reply With Quote
Old 05-29-2020, 07:45 AM   #16
dick_barton
My Country: Wales
Quote:
There's also an smd resistor in the photo I posted that I could not see on his original photo. Is it on your board and can you see its value.
Old 05-29-2020, 08:42 AM   #17
diif
My Country: England
It's tiny and black which is why it doesn't look like it's there. It's in circuit with the two black devices either side of it, it sits lower than them so it's very unlikely it could be knocked off, unlike that cap.
Old 05-29-2020, 12:29 PM   #18
nomoresonys
My Country: U.S.
Yep, looks like it fell off or was removed, what's the tv history? another pic. there: https://www.ebay.com/itm/LG-32LB570V...-/273575219348
Old 06-02-2020, 04:44 PM   #19
axon18
City & State: Ovar
Good evening,
Thank you all for your help. I ended up buying a new card.
Old 06-02-2020, 06:38 PM   #20
nomoresonys
My Country: U.S.
Ok, let us know if it works.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
