Samsun Rv511 (ba41-01433a ny) schematic needed
    Hi Folks
    I have a Samsung RV511 screen stays black, tried changing screen but still the same, no external output either. Fan runs high speed constantly
    Anybody got a schematic or seen this issue before.
    Re: Samsun Rv511 (ba41-01433a ny) schematic needed
    Could be that the gpu is fried
    or you have bad ram.
    try swapping the ram first
    and then perhaps run a reflow
      I swapped ram still the same just spoke to a guy who has similar and swapped Cpu and it worked. I never had a faulty Intel Cpu before. I would only reflow as a last resort and if I was in a position to then reball if the reflow worked. As I dont believe in reflowing unless it leads to reball.
      Its very hard to find a schematic for this mobo.
      Thanks for the reply.
        Issue is fixed now. After speaking to another user who had black screen and fan running full speed he swapped out his i3, then everything worked fine. I have done the same and laptop working again.
        Thanks for all the assistance.
          Originally posted by scobie_21 View Post
          Hi Folks
          it's similar to this diagram:
            Yes thats the one.
            The issue is sorted but thanks for the diagram.
              well mine is with a P6200 cpu , tryed with a i5 , and another p6100 .. but still same , rplaced bios , but still same
              all S0 are present when turning on . so possible problem with PCH
              bad luck for me
                thanks
                  Got same issue with same board, replacing P6200 with i3-380 solved the problem
