Quanta QL8 / TW8 schematics request
    FOXCONN ML94V-0
    Totaly dead no led .
    i need schematic.
    Re: Foxconn ml94v-0
    Thats a Quanta QL8 / TW8 motherboard.
    And this is the discrete GPU version of yours, might help.
    And if you can share the symptoms I can help u. I repaired lots of that motherboard when I was working on a RMA center.
    Most problem is shorted mosfet,tantalum caps and cold solder at Vcore chip.
      Re: Foxconn ml94v-0
      Thanks for reply tomodachi.
      ALW 5v & 3v absent i chek pu8 ISL6237IRZ-T pin no 6 18v but pin no7 LDO 0 v & 0 ohm reading between pin no7 to gnd icheck pc121 it is ok please your opinion.
        Re: Foxconn ml94v-0
        What do you mean LDO is 0 ohm ? is it totally shorted ? also check the +3VPCU rail to the ground.
