IBM R50e schematics
    Re: IBM R50e schematics
    Originally posted by rtstorm View Post
    Q4
    pin1 - 0.3V
    pin2 - 0.56V
    pin3 - 0V
    pin4 - 0V
    pin5 - 0.3V
    pin6 - 0.3V
    pin7 - 16V
    pin8 - 16V
    L5 coil have 0.3V on both side
    its that fet ok?
    keep in mind that`s a dual N-channel fet
      @ atsio
      Q13
      pin1 - 2.99V
      pin2 - 2.89V
      pin3 - 2.89V
      pin4 - 1.2V
      pin5 - 15.96V
      pin6 - 15.96V
      pin7 - 15.96V
      pin8 - 15.96V
      R422 i cannot find (KODIAK program wont display it)
      R453 one side is 16.3V and other side is -7.8V
      I did not use the battery while i was testing.
      What is KODIAK?
      Remove D10 and D19 and inject 16v with regulated power supply (use quite thick cable for say, 5 amps) to pin 3 of D10 and check if laptop starts.
      After, check voltages on pins of U61 I asked for in my previous message.
        i try to remove D10 and D19 then i inject 16V on pin 3 of D10 laptop wont start.
        U61:
        pin57 - 16V
        pin34 - 16V
        pin55 - 0V
        pin52 - 0.5V
        pin54 - 4.4V
        pin10 - 0.2V
        pin11 - 0.1V
        pin44 - 0V
        pin58 - 0V
        pin59 - 0V
        Kodiak is the software i use for fide the device on MB. there is no marking on MB itself.
        ...the quieter you become the more you are able to hear...
          @ atsio
          this R453 has F marking on it (probabbly fuse) wont pass continuity test. i think it is dead
            i bridge the F but nothing changed, still no power on MB
              hey where is the BIOS IC? is it U15, U53 or U3? maybe i sloud chek bios?
                please help me extract dump file from this
