foxconn v181 mbx-272 schematic
    please who can share the schematic foxconn v181 mbx-272
    1P-0128J00-6011 Rev: 1.1
    thank you
    regards
    Re: foxconn v181 mbx-272 schematic
    This netbook has a blank screen problem, I've tried to flash BIOS but the problem still. already tried to replace it with a good RAM.
    several measurement points, among others:
    PL38=1.09V
    PL39=1.5V
    PL31=1.0V-1.3V its look like wierd ?
    PL34=0.9V
    without a schematic, it is very difficult to trace
      reflow done?
        Originally posted by dj_ricoh View Post
        reflow done?
        thanks for reply.
        Unfortunately not, because I have not had a BGA machine. try this week asked for help by a friend who had a BGA. I hope this can solve the problem
        regards
          "PL31=1.0V-1.3V its look like wierd ?"
          check this again and try to start only on battery
            for comparison I used a schematic acer quanta zhg because both use the IC OZ8380aln.
            on pin 9 LX2 measured resistance 13ohm, while the pin 16 LX1 146ohm. for a processor that can not be removed like this netbook, how should the coil resistance ?. This direction towards NBcore
            before reflow motherboard I want to make sure nothing is short
              this schematic
                problem solved
                before reflow, I think and analyze again.
                try to power netbooks, touch the cpu and chipset and feels warm, meaning the cpu and chipset are already working.
                during the search for the schematic, accidentally discovered this tread https://www.badcaps.net/forum/showthread.php?t=41172. I finally decided to once again flash the BIOS with the file. and it worked.
                thanks for badcaps, specials for dycc
                  Hello techs,
                  Does anyone have the MBX-272 V181 schematic?
                  I have a problem with rezistor in photo. (attach...)
                  Thank you...
                    Foxconn MBX-272, This platform have no schematic
                      OK, does anyone knows what resistor is that?
                      If anyone have the netbook to measure the resistor?
                      SOS is the only problem and I cannt fix it!!!!!
                        That resistor is 0.00 Ohms.
                          Hi, I think I have the same problem, may I know how you flashed the bios? Anyway to do on the board or I need to unsolder and flash from computer, I have the following flasher, but I've not used it, I will research now online:
                          CH341A 24 25 Series EEPROM Flash BIOS DVD USB Programmer
                          I got it a while ago but never tried it. I have all the equipment to unsolder it.
                          Cheers
                            I figured this out now, for anybody else follow this video:
                            https://www.youtube.com/watch?v=L0ChYNwunUE
                            You can buy the programmer off ebay for around 3£.
                            I re-used the chip after erasing it and seamed fine.
                            Cheers.
                              Originally posted by quic307 View Post
                              Hello techs,
                              Thank you...
                              512 ohms
                                Originally posted by JIMBOYVOLTRON View Post
                                512 ohms
                                thanks i put 510 ohms its working
