anyone with asus g53sw schematic
    anyone can share this schematic for this board g53sw ?
    if also a bios dump would be nice
    Re: anyone with asus g53sw schematic
    Everything from Asus with 53 in the typenmbr is very hard to find. The onliest thing I could find in your case is the boardview that looks like it, sorry.
      do you have a good program to see board view files ?
        Here are 3
          I have this file mite help have flashed it works
            Here is the link to download the boardview software
            https://onedrive.live.com/redir?resi...3CB14281%21735
              thk you my friend thats what i call a good job
                strangely this bastard ,was replaced dc jack . wwe tryed worked nice , then we assembled , and started to turn on and off , we noticed there was problem on the pwr on socket , we replaced , but once we insert dc jack machine turn on , then turns off after few sec , if i unplug and plug again the powerboard is will turn on again , will first remove components regarging this circuit , then will make direct bypass to ITE , if it turn on and works then its a problem somewere on the the poweron circuit
                , but in any case , bios is welcome for test
                  and also if i remove the powerboard and insert the dcjack machine will turn suposedly on , and stay on , but no image . but if i remove the dcjack again and insert it turn on again and stay on . with the pwerboard , it turn on once i insert dc jack , but then it will shutdown 4 or 5 sec after
                    Hello!
                    I have one G53SW, fully working.
                    How can I help you?
                    If you want to, send me PM
                      pin 125 you have 3.3 voltz suposedly ? , i dont have any voltage on my on off button
                      im thinking something wrong this this KBC
                      and also i have always 0 vlts on pin 125 of KBC , and it shouldn't with or without powerboard , with machine beeing on or not
                      this is totaly weird happening , only leading me to the KBC problem , but must make more test , gonna lunch and be back in 1H30
                        Sorry, I forgot to atache that file.
                        For me the proper one is Asus TSIC, but that one is already send by Cyberhack
                          The G53SW is also an K53SV mobo ???
                          I have a pdf file from this one from China site but it wil not open.
                          Maybe one of you guys can succeed in opening it and see if that is the schematics. Let me know if you succeed because I want them as well.
                            magnegh , send me your dump please .
                              also any of does programs are allowing me to open this .ASC files
                                These 2 work together
                                  but its a g63 not k
                                    What number the mobo has?
                                      G63sx
                                        Here you go.
