anybody has this model? it has to be VERSION 2, Please guys
hp 8460p schematic please guys
Re: hp 8460p schematic please guys
Is it this one?Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
ok so heres the problem with this laptop, maybe someone can give me some pointers:
Laptop wont turn on at all, it shorts the adapter and it makes noises when you plug it into the jack. there this mosfet 331bqbd that gets really hot while plugged in, but i replaced and still the same thing.
If the mosfet is removed the issue goes away. But since i dont have the schematic its hard to trace it. the motherboard model is 6050A2398501-A02.
The mosfet in question is Q514.
Originally posted by Blacktek View Postok so heres the problem with this laptop, maybe someone can give me some pointers:
Diode/Beep Mode on a meter. Red probe on GND. Black probe on the points.
Find the short and inject a voltage on that rail at the same rated voltage. Use a power supply or bench top supply. This should make whatever is shorting it out HOT or blow it up.
Originally posted by BCConnectionLLC View PostHave you metered on either side of the mosfet when removed for a short?
Find the short and inject a voltage on that rail at the same rated voltage. Use a power supply or bench top supply. This should make whatever is shorting it out HOT or blow it up.Last edited by atsio; 06-07-2015, 12:40 PM.
Originally posted by atsio View PostAnd if he needs to supply i.e. 19v and the fault is a fet and this 19v end up to a chipset or even CPU, then what?
there are 2 cases in the forum with upper fets for cpu where bad and they turn off the adapter.
i think in this case its not the problem or not similar.Just cook it! It's already broken.
Shorted CPUs must be a common thing for you because it seems to be your suggestion every time.
Although if you think injecting 19V on a 19V rail will blow up the CPU then I guess the CPU needs a better regulatory circuit on boards you work on. Its not like the main Power rail just feeds 19V to the CPU.
I do this because my power supply wont shut off because of a short. Unlike the adapter which protects itself.Last edited by BCConnectionLLC; 06-08-2015, 08:29 AM.
I think I am not the only one saying this (from Elvikom's training thread)
There are two main points to notice when performing a short-test:
1. In case when heat can be felt on the core of either of the bridges or graphics card, short-test should be immediately stopped. In this cases usually one of the transistors working with the DC controller is shorted and there is a risk of connecting high e.g. 19V voltage directly to the bridge or graphics card which are usually powered by 1V to 5V voltage. In this case you can't tune up the voltage above value, which is normally operated in lower values (for example, for the 1,8V power rail you can tune up the voltage only to 1,8V value maximum!).
https://www.elvikom.pl/szkolenie-nr-...opow-t986.html
Originally posted by BCConnectionLLC View PostWhere did I say inject 19V on a 1v or 5v rail?
I said inject 19v on the 19v main power rail that normally sees 19V...
If there was a short directly from 19V rail to the CPU then its already done its damage before you ever start testing.
Originally posted by atsio View PostYou still do not get it. Usually the drain of upper fets on voltage regulators is on the 19v rail. If the fet is open and you inject 19v on the 19v rail, 19volts end up on the source rail of the fet (whatever volt is that).Last edited by BCConnectionLLC; 06-24-2015, 05:24 PM.
Originally posted by rievax_60 View PostWell done.
Also that is why I sometimes say to not apply more than 1v test when finding a short. There might be a shorted High Side MOSFET sending the test voltage directly to CPU, NB or GPU.
