Asus S301 Schematic or boardview
    Re: Asus S301 Schematic or boardview
    Originally posted by JaroTech View Post
    If you want to confirm a short on the 19V power line, you must remove the resistor 10mOhm, but you did not give me the picture I asked for. So I don't know where is this resistor.
    Sorry, but must have missed this request !
    Even Now i don't see the post where you ask this?
    Can you point where is the area of the mobo you need the picture ?
      It's the post #9 on the first page.
        I did answer on Post 11, anyway here a better picture with all the area you asked.
          Sorry, but I can't find the resistor from the pictures you already post. You should start with changing this chip (BQ735), if you still don't have 19V on the motherboard, we need more troubleshooting to find the defective component. (But I was right about the screen)
            Ok, since only 3 of us have participated to this thread, if the solution is the above, i will give 20 bucks to each.
            Just a little sacarsm.
            Will kreep updated once i receive the new BQ.
            PS: i will order only after the holidays
              @passete, I don't do this for the money, give the money for a good cause. I'm an Electronics Technician, I know what I talking about for your problem. But i don't have the schematics for your laptop, so, i extrapolate the troubleshouting from what I have.
                Here again the barrier of language !
                You misunderstood me Cousin , I appreciate all your time and wisdom .
                Was hoping for others to ... ohh well,... hope you understand
                PS: Will try to find this IC on my Mobos collection, otherwise I will order it.
                  Will a BQ25A work in replacement of a BQ735 ?
                  Or is there a compatible IC ?
                    Hello, I have the same problem.
                    How did you solve it?
                    Thank's
                      Received today the bq735, i don't see any change, still no voltage on bios ic, power switch etc ...
                      @JaroTech buddy, what is the next step ?
                        10 milliOhm resistor was located near sw5901 visible smd part with R010 on it
                          Hey buddy, thanks for your reply.
                          I don't understand what you mean, you want me to remove this resistor ?
                            I just want to make sure that you have no short circuit as jarotech said at post#40 (cont'd post#40)
                            what about resistance on this resistor respect to gnd? low or high
                              I don't have any continuity on the 3 Points that i've measured, but i get a low voltage, 0,98V.
                              This is strange, if i use the metal cases of the usb/hdmi as ground, i get no continuity, but i found a point on the mobo that i can measure 0,03 Ohms on the 3 points
                                So, you've found short circuit at 19v rail.
                                use asus ux31a2 scheme as reference, on 3 points what you've measure it was P_CHG_PATH_19V_SHAPE
                                  HI, i have the same problem and i changed the two fet neaarly the power boton (as show on the joined picture), and the pc turn on an reborn.
                                  Thank to all for your help
                                  Eric
                                    Eric
                                    Are you 1OO% sure that your problem was the same ?
                                    Before changing the fets, what were the voltages on those 2 ?
                                      SOLVED, SOLVED, SOLVED, ....
                                      Lol, it was just this 2 Fu""""" Fet's near the input Socket !
                                      Un Grand merci a toi nevermind1993
                                      Also a very Big Thanks to Meritosari for your patience Buddy, if one day you visit France, i will pay a Dinner
                                      To Finish, also a big thanks to the 2 Other members that Helped, you guys are Great.
                                        You're welcome
                                          Hi all, can anyone tell me the name of those fet , i cant find them on ebay or similar for buy them.
