Toshiba L300 6050A2170401-MB-A03
    Hi friends, This laptop had NEC/Token Cap Problem. I Removed it and fill by 4x330UF and it worked fine and battery also charged without any problem since last one month. Now i am having a problem. when i switched on it is not showing POST screen or logo and in that time it shows only white screen. Thereafter its loading windows 7 when it showing desktop the screen resolution is changing itself many times after that it screen freeze. What happen to it ? anyone having same experience and anyone solved same problem. Please help me ....
    Re: Toshiba L300 6050A2170401-MB-A03
    Anyone having schematic & boardview for this board
      ok here it is ..
      sigpic
        Originally posted by samanthban View Post
        ok here it is ..
        Thanks Samanthban. Do you have Boardview for this ? And also did you solved that Dell 3521 +3VALW Short to ground problem ?
          sorry no boardview with me .its abnormal fail on that ? searching for case study with same issue
          sigpic
            I am having Dell 3521 with +3VALW short to ground problem. I try to find the short since last 2 days. But wast of time because i removed lot of components but the short still.
              My case is different this will short to ground when power connect .after five minutes that will vanish.
              sigpic
                ok here it is ..
                Thanks samanthban
                  thanks
                    no need for schematic or board wiev. u have problem with graphic chip
                      Its having intel chipset only. it doesn't have any nvidia or ati chips.
                        yep bad northbridge...
                          thanks
                            Download and reset bios for Toshiba Satellite L350 6050a2170401-mb-a03 dump
                            https://www.youtube.com/watch?v=gwejmNEH6C4
                              thanks
                                thanks
                                    thanks
