A1278-2326 5.5 schematic and board vew wanted
    Hi all, i am trying to locate a schematic and board view for a mid 2009 macbook pro A1278-2326 5.5.
    having problems with the front usb socket i keep getting a message informing me that it is using to much currant and that's with nothing plugged in.
    had a root round and found out that if i put a pendrive in the socket i get 3.2v on pin 3 of the usb socket and nothing when removed!! usb socket 2 works as it should, i wonder if anybody else can put some light on this.
    i have replaced U4690 AND d4600 and a couple of caps, can't go any further without schematic and board view. Thanks, Manson.
    Re: A1278-2326 5.5 schematic and board vew wanted
    Need the motherboard number, usually starts with 820-
      Hi, thanks for getting back to me.
      it's a 820-2530-A Thanks, Manson.
        Here you go.
          Hi, thanks for the files but i cannot get them to work properly.
          i can open the schematic on it's own but when i open board view and go to open file it tells me i don't have permission. ( i have full permissions on my computer ) this is on windows 10 using pdf for the schematic.
          i als tried it in windows 7 and all i get there is a notice about a floating point so i am now lost.
            I run the BRD-T_link.exe as Admin and open K24.brd with no issues.
            Openboardview also opens the .brd file fine.
              Hi whatever I do I cant open this schematic in board view or open boardview it tells me theirs no program associated with it and I don't have permission to open it and I have tried administrative no go I tried it in windows 7 and I get the message
              (error floating point)
              the schematic opens ok on its own no problem, its just when you try to open it in the board view program!!! Help.
                You're doing it wrong.
                The schematic is a pdf and you use a pdf reader to view such as Foxit, Adobe or Sumatra.
                The boardview .brd file needs a viewer such as Landrex or Openboardview.
                  Thanks, all ok now, not used to board view software (old school) but got there in the end, Thanks, Manson.
                    Thank you.
