Lenovo V310-15IKB SCHEMATIC
    Kindly assist me with Lenovo V310-15IKB SCHEMATIC
    DA0LV6MB6F0 Rev E
    Re: Lenovo V310-15IKB SCHEMATIC
    i wont sechmatic
      Espero les sirva
      I hope it serves you
        Thanks @Albertoq
          hey, thanks i was looking for this, now i have an issue... Lenovo in the infinite wisdom has not put a SINGLE silkscreen identifier in the entire motherboard(save for some connectors).
          Making it extremely hard/near impossible to identify some components.
          specially when the component models in the schematic do not correspond to the component in the motherboard(thus, searching for some mosfets i see on the board yields nothing on the PDF)
            Boardview .
              Originally posted by SMDFlea View Post
              Boardview .
              I think this file is corrupt. Is it possible for you to check?
                File is ok.
                  thank you
                    Thank you
                      Thank you
                        Thank you
                          Which voltage is supplied by power supply left from the bios battery? The chip is a 3B=4J. I have 2 motherboards with this problem. It takes about 2A when I voltage inject 1V, only the processor get a bit warmer. Thanks!
                            PU3002 is a Richtek RT7290AGQUF 3B=
                              Thanks!!!
                              What voltage does or supply? I don't have the correct schematics other than the indicative one provided in this thread.
                                Thank you
                                  Thank you
                                    Thank you
                                      Thank you
                                        Thank's
