good morning colleagues , i need a urgent help, I am repairing a phillips lcd tv model 42PFL3603D/27 which don't turn on. I found a faulty diode in whose body is written as T2D 83 .this diode is in the power supply. Here is the part number of the power supply: Philips 272217100569 and the model of the power supply is 2300KEG031A-F. I tried to find this diode across the internet to see its specification and find an equivalent, but I haven't found anything, there is only a mention on the internet of this diode and say it is a zener. I tried to find the schematic of the power supply but I haven't found. The position of the diode on the power supply is: D106A. Hope you can help me find the specification and any equivalent for this diode T2D 83, because I'm taking a week try to find any information on this diode and i couldn't find anything. thank you very much. regards.
HELP replacement or equivalent of this diode T2D 83
Re: HELP replacement or equivalent of this diode T2D 83
Pictures of the board, both sides will help in determining the function of this Diode.Never stop learning
FYI
https://www.badcaps.net/forum/showthread.php?t=23233
ST02D-170
May be available here?
http://www.donberg.ie/catalogue/t_2d.htmlPlease upload pictures using attachment function when ask for help on the repair
Originally posted by charless1 View Postgood morning colleagues , i need a urgent help, I am repairing a phillips lcd tv model 42PFL3603D/27 which don't turn on. I found a faulty diode in whose body is written as T2D 83 .this diode is in the power supply. Here is the part number of the power supply: Philips 272217100569 and the model of the power supply is 2300KEG031A-F. I tried to find this diode across the internet to see its specification and find an equivalent, but I haven't found anything, there is only a mention on the internet of this diode and say it is a zener. I tried to find the schematic of the power supply but I haven't found. The position of the diode on the power supply is: D106A. Hope you can help me find the specification and any equivalent for this diode T2D 83, because I'm taking a week try to find any information on this diode and i couldn't find anything. thank you very much. regards.Never stop learning
I'm curious about this myself. I am working on this model now and have used the shopjimmy kit to refurbish the power board. The backlights were shutting down apparently after reaching a temperature threshold. It could turn back on after a limited time. I looked at the power board and replaced 4 caps that were bulging, but it didn't do any good. I took the back off the tv and let it run and it never reached that temp threshold to turn off. And by turning off, the sound would still remain, but no picture. I decided to get the shopjimmy kit which included fuses, transistors, etc. It was about 44 pieces and I was only going to replace the transistors, resistor, diodes, etc that were easier to replace on the main side of the board. I wasn't going to actually replace any of the tiny SMD parts unless I actually had to. Those are a lot harder to replace because you could damage it taking it out and damage it putting it in, if you weren't sure it was bad in the first place. I did this and now I am blowing the main fuse. I checked everything over and I don't see any issues. I replaced the fuse again and blew it again. I see D106A seems a little charred on the lead, so I removed it. It appears charred on both ends of the leads. I tested and it is open both ways using diode check function and continuity test. I can't seem to find this diode anywhere. Does anyone know the equivalent to this diode? The numbers on it are slightly different-T2D81 and the 1 is underlined.
I'd like to reopen this and see of anyone had luck finding the T2D replacement diode? I have this schematic I found, but I'm not sure what to believe as R104 is burned on my board, the bands shows it as a 204k reisistor, but the shematic says 100k. It also shows UF4007f or D106 where the T2D diode is. But it's D106A on the board..
So I'm confused here if anyone has sorted this out I'd appreciate the help!
cant tell if its black or purple
diode looks like a plain jane 4007Last edited by petehall347; 12-08-2019, 05:30 PM.
Originally posted by petehall347 View Postcant tell if its black or purple
diode looks like a plain jane 4007Last edited by kevinm34232; 12-08-2019, 06:31 PM.
R104 in your board revision is 200K, it is part of RCD snubber network.Never stop learning
You need to look at what is printed on the diodeNever stop learning
Can wee the pictures of the bottom side of the board?
BTW, the picture of your board does not match with the diagram.
May be you should show the pictures of your board.Last edited by budm; 12-08-2019, 07:26 PM.Never stop learning
Is this the EXACT matched to your board?
https://www.shopjimmy.com/philips-27...pply-unit.htm#
Based on the picturees from shopjimmy:
R104 is not for the snubber, it is for input Voltage Start of SMPS IC pin 8.
D106A is the snubber diode connected in parallel with the primary winding for the SMPS transformer.
The circuit you shown uses RCD snubber, but the board from shopjimmy does not use RCD snubber, it uses diode snubber only, I.E. T2D 83.
Is R104 tested bad?Last edited by budm; 12-08-2019, 07:41 PM.Never stop learning
Did you lift one leg of R104 off the board and check the resistance? It will take very high Voltage to burn up that 200K resistor and pin 8 of the IC has to also be shorted to ground.
Did you test D106a off the board? It should show open circuit.Last edited by budm; 12-08-2019, 07:47 PM.Never stop learning
Well I was way off. You are right, resistor shows 197k ohms and D106a shows open.
I just assumed when I saw the burn marks.
For U101 looks like pin 7 Drain burned up. Is it possible it's just U101 that's bad?Last edited by kevinm34232; 12-08-2019, 08:38 PM.
