Bad dell LCD screen
    Bad dell LCD screen
    My friend got a nice Dell dimension 3000 with a dell lcd screen. Problem is the power light will turn green like its getting signal and power, but the screen remains blank. They tried different dsub cables too, that did nothing.
    I told them it might be the lamp went bad or that it has bad capacitors.
    IDK the model number or anything like that...they just told me today at school.
    Re: Bad dell LCD screen
    Seems that you have a backlight failure. This requires some skill to dismantle and then check the back light inverter electronics. Sometimes you can be lucky and only have to replace a small fuse.
    So to check it out it must be opened up, if you feel up to it. Then post some photos of the electronics boards. You also need to identify the model number of the Dell monitor if you need help, too many versions around.
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
      The Dell monitors are a pain to disassemble I had to repair by brothers Dell awhile back an E193Fpc the back cover is almost totally secured to the front with clips.
      To remove it remove the 4 screws securing the stand to the monitor then remove the 4 screws under that securing the back cover to the front.
      Now comes the tricky part look into the vents around the monitor with a flashlight you will see the clips they are all around the sides.
      I released mine with the bottle opener attachment on my swiss army knife.
      Insert the thin opener into the vent opening closest to the clip and put it against the clip now push outward to disengage the clip.
      Do this all around and the cover will come off.
      This is a little like disassembling an Ipod it's tough the first time but you get much better at it.
      And just like the Ipod it goes back together much quicker then when you took it apart .
