I have recently finished adding A/V out connections to two Sega Master System 2 consoles.
The SMS2 uses the Sony CXA1145P IC which provides a Mono audio output, and Composite, S-Video and RGB video outputs.
The only thing lacking is the wiring and a couple of components, which are easy to add (see: http://knol.google.com/k/konsole-kra...gsu6gmugnec/3#)
My modification is essentially the same, except it looks much better and uses shielded wire for the signal wires.
Now, everything works fine, the magic smoke is still inside, I don't doubt the modification itself as many people have done it.... BUT with some positions of the DC power plug, I get buzzing in the audio.
If I slowly turn the plug around in the jack, at some points, I can make the buzzing go away, in some places, power interruption, and the console resets.
I get the impression that the jack is worn, there is a bad connection, possibly mild arcing causing the buzzing? Maybe they need cleaning?
Is this a known issue with old power jacks (remember these console were made in 1990) or could it be something else?
