Following on from my previous soldering iron thread, I decided 'what the heck' and bought myself a cheap 80 watt iron from my local hardware store.
Well, let me tell you this thing is powerful! I tested it out on an old board and couldn't find anything it wouldn't heat up. Capacitors came out much much easier, cleaning holes was a breeze, even those on power planes.
Of course, everything has it's downside, and being an unregulated iron it gets mighty hot. So hot in fact I was cleaning the tip more than I was soldering as it oxidizes FAST.
Can't measure the the temperature (there's something else I need) but I'm guessing it's 450°C+
So in hindsight maybe something a little less powerful would have been better but there's got to be a solution, right?
I started searching for mains-rated circuits that can control speeds\power etc and came up with a few things, found a few circuits for light dimmers.. then I figured, hey, why not just use an actual light dimmer - since I have the guts of one in my junk box anyway.
I recalled that last time I tried, it didn't work, but on inspection I found that one of the wires had a completely broken solder joint, so I reflowed that, tested with a lightbulb and away it went, perfectly!
Haven't tried it with the iron yet but I see no reason why it shouldn't work.
Calibration will be a problem, I guess I'll have to stick a label on by the knob and write some marks\notes after some experimentation.
Also there will be no feedback so no controllable recovery time but I'm hoping the large thermal mass will make up for that.
I'll probably add an LED as well which might show some kind of status as it will hopefully dim along with the iron.
Anyway, I should ask: Has anyone tried this idea before and if so, did it give good results?
