Hi lads, I'm looking at a spotlight that is getting 0 voltage on it's 240V lightbulb rails... but I'm a bit confused.. There is a large 20uF capacitor marked as 250V AC across the live and the neutral, just after the fuse.. After a quick google, I've discovered that this is to prevent arcing when it is switched on, but there really isnt a huge amount of information on using a capacitor in parallel on an AC circuit. Can anybody clarify this for me...
I assume that I can just pull this out of the circuit and switch on and it will work away the same.. or is there a large possibility of arcing with this type of circuit.. i.e. a spotlight..
I think the cap may be causing the problem even though it checks out fine with the ESR meter.
