Hello from Greece !!!
This is a Voltage-controlled oscillator (VCO). Αn oscillator that its frequency is controlled using a voltage signal. The VCO described here provide both triangular and square wave output. The control voltage can be varied between 5 mV to 5 V, to produce oscillation frequency from 10 Hz to 10 KHz.
Can someone please explain to me briefly the operation of the circuit ?
thank you
thank you
