hi can anyone tell me if a replacement has to be out of the same tv ,I have just bought a replacement fitted it and the fault is the same it wont come out of stand by thank you
17pw26-4 replacement
Re: 17pw26-4 replacement
as far as i know as long as the psu is a exact match 17pw26-4 there shouldnt be a issue do they look identical on the top of the board and also on the bottom side? have you tested both the old board and new board voltage on all the connectors are they identical?.what tv are you working on make and model it may be a main board fault im sure tom66 will chime in regarding these 1726pw-4 im sure he worked on a few
yes they are spot on the same the tv is a Sanyo CE32LD47-B the old power board the stand by light stayed on the replacement board the stand by light flashs all the voltages are ok until the main board is plugged in the the invertor drops to 18v the 12 volt drops to 8 the 5 volt drops to 3 I hear a faint clicking on the power board and the optical light flashs at the same rate as the clicking
