Had this LED 'bulb' in a beside lamp because incandescent and CFLs were too hot in there. Cost $15 and claims to last 20 years (Yeah, right!)
Worked great and ran cool for a couple of months, then started flickering sometimes, and eventually died. Funny how a 90 cent incandescent bulb lasts longer than CFLs and LEDs both costing $15.
I found that the light diffuser can just pop straight off, which reveals a small PCB with 20 SMD LEDs on it underneath. The PCB has a metal backing and is screwed to a metal heatsink underneath that. Below the heatsink is the driver circuitry, which outputs 120v DC unloaded. I didn't bother trying to get into that since it works and I didn't want to cause damage (at this point).
It's clear from just looking what the problem is! Two of the SMD LEDs have burnt out.
What's interesting is that assuming a working voltage of 120v DC for the 20-LED string, they have a 6v forward voltage. I haven't heard of any this high but I suppose they have two LEDs in series on the same die\in the same package. Makes sense going by the two little bumps I can see though the yellow coating, anyway.
I removed the dead LEDs and measured them at about 3x2.5mm which doesn't correspond to any known LED package I know of.
The closest I found were these: http://lumis-led.en.made-in-china.co...-LED-0-5W.html but it's not really worth it.
If anyone knows a good source for new LEDs, I might give repair a try for a laugh. Otherwise, I'll probably just cut the end off and see how they built the LED driver, maybe re-use it and the rest of the working LEDs for something else.
