I've a diode in a tv psb that has a reading forward and bias. This is with it in circuit. Out of circuit, it tested normally. Any thoughts?
Diode test results show reading both ways
Re: Diode test results show reading both ways
You need to trace out the connections to see if the diode is connected in parallel with other device or not.
Pictures of what you are testing?Never stop learning
What the fault with the Tv ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Nope, you are looking at some of that grey adhesive, not a ruptured capacitor. Even so, if there were a problem right next to the main primary side rectifier bridge, do you think that it would cause a secondary rectifier to fail or read incorrectly? I think not.
The fastest way to check the diode is to desolder one leg and re-measure. It is probably a Schottkey and will measure somewhere around .2 volts forward.Is it plugged in?
Originally posted by AcGeorgiegirl View PostHere's a pic of the psb on the tv I am working on. The diode in question is circled. Would it help if I took the same pic of the underside, to show tracings?
We do need good clean straight shot of the bottom side of the board too.Never stop learning
Originally posted by ReeceyBurger123 View PostWhat the fault with the Tv ?
History of the TV?Never stop learning
Originally posted by budm View Post+1
History of the TV?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Post #9Never stop learning
Originally posted by budm View PostDoes it show conduction in both direction if the white connector to the main board is not in place.
Originally posted by ReeceyBurger123 View PostWe need to be taking a few more baby steps lol
I started this posting because I didn't get a response about the diode issue there, and thought is was important....
There's no standby led lighting up. Without the main board connected, I get 5.14 on the 3 pins labeled for 5v for what I assume is standby(con isn't labeled as such...see pics). With main board connected, I get the following pin voltages:
1 gnd
2 5vcc 5.21
3 5vcc 5.21
4 gnd
5 5vcc 5.21
6 13vcc 12.71
7 13vcc_AUD 12.71
8 gnd
9 PWON 3.03
10 ACD 3.46
11 gnd
12 BLON 0
13 DIM 0
I realize that pins 6 & 7 are supposed to be 13v. I don't know what pins 9 & 10 should be, nor 12 & 13. Also, when checking diodes and fuses, I found that D210A on the Secondary side has reading both ways (208 and 1342) I keep running into this, and am wondering if this is normal on the secondary side, or not? I usually don't take the diodes out of circuit when I test them...maybe this is why I get this?
In plain English it sez:
The PSU has been turned on (pin 9 &10)
there backlight's are off (pin 12 &13)
So the BLon signal from the main board to the PSU to turn on the backlights is missing. Look at the mainboard and see if the if the BLon voltage is missing there too. If it is, you've got a main board problem.
Originally posted by AcGeorgiegirl View PostIt doesn't show conduction in both directions then. But, it does take a second to get to open OL, after cycling a few numbers around. Here's a pic of the back of the board.
Same test but WITHOUT other boards connected to the power supply board, resistance is???Never stop learning
Originally posted by budm View PostOK, let me get this correctly, when testing the diode on board WITH all the connector in place, it shows resistance in BOTH direction, what is the resistance? Ohms, K Ohms?
I went ahead and followed the BLon pin wire from psb to main, and tested at the main side. It is still at 0, and so is the DIM pin.
Disregard.Last edited by budm; 01-11-2017, 03:05 PM.Never stop learning
