Mean Well RD125-1224 switching power supply using a NE1101F ic chip
    Here is the data sheet for this ic chip it is for A or B version not for F version but the letter has to with what frequency it is using for this version
    https://cdn.badcaps-static.com/pdfs/...7acd988ac4.pdf
    This is a dual voltage output version ( output 1 )12 volt / output 2 24 volt output
    There dose not seem to be much circuitry on the secondary side of this power supply
    Curiously got the best of me and I had to see how this power supply was made
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
    Re: Mean Well RD125-1224 switching power supply using a NE1101F ic chip
    Update
    Well my engraving machine is happy with this switching power supply
    I had up the voltage a little bit because my 24 volt output side was about 0.500 volts low
    brought up the 24 volts to exactly 24 volts and the 12 volts side was about 12.5-something
    which will work fine
    Now I have to make an enclosure ( with the 3D printer) for end of this switching power supply because I want to cover the input 120 ac current terminals so I do accidentally touch those terminals “ safety first “
    I also have hook up the controller power supply switches I still have a lot of work to do on this project
    My laser ( and or ) spindle motor and engraving machine controller can all work off of the same switching power supply instead of 3 different switching power supply ( bumper)
    9 PC LCD Monitor
    1 Dell Mother Board
      Update
      The switching power supply has been running for last 2 hours now and the voltage on the 24 volts is now it 24.44 now and now the 12 volts is now 12.44 volts which also fine because the only thing running right now is the engraving controller
      9 PC LCD Monitor
      1 Dell Mother Board
        Be careful when buying a dual channel switching power supply because some seller are miss interpreting the specifications of this type of switching power supply
        Putting the maximum amperage for each channel and not what each channel outputs if you use both channel together at the same time but on the data plate shows the maximum output if both channels are used at the same time and does not tell you what the maximum amperage is if you use only one channel which to me is a mistake on there part
        This would not take that much space on the data plate for this information really
        9 PC LCD Monitor
        1 Dell Mother Board
          Couple of things I forget to mention
          The laser that I have with the engraving machine at 100% laser power at 12 volts using engraving controller switching power supply controller which was about 2 amps this was a test just to see if it could handle the load
          But what I going do instead is use the 12 volts for the laser and have the engraving controller on the 24 volts
          When I am using the spindle motor will be on 24 volts and the engraving machine controller on 12 volts side
          9 PC LCD Monitor
          1 Dell Mother Board
