Magneto voltage limiter
    Re: Magneto voltage limiter
    The challenge with LEDs is that to take advantage of both positive and negative half cycles, a full rectifier is necessary. And a full wave rectifier would create a new ground separated from the chassis leading to cut the regular ground (chassis) connection from the concerned pin of the LED and bringing a new wire from the rectifier's ground.
    Would need a huge capacitor if he's insisting on incandescent
    Why a huge capacitor? Thermal inertia of incandescent lamp should smoothen any low rev flickering.
    The only thing I'm a bit concerned about is the reverse breakdown
    Agree. Also the reverse voltage between base and emitter of the transistors shall not exceed the maximum ratings value. A protection diode could avoid it.
    and add a digital speedo!
    That could be some great improvement!
      It wasn't for the flickering problem - it's being a small "battery" for preventing low voltage dimming for a while when you're running slow or stop. That is, unless the voltage from the magneto is always above your desired voltage setpoint plus dropout?
