A 2200lm 7057 LED car lamp...
    Re: A 2200lm 7057 LED car lamp...
    led are crap if used wrong as in most cases i see .. they whoever they are seem to think running them at the max is a good thing .. i tame the little buggers with a suitable resistor to run at the lowest current whilst it is as bright as it needs to be .. they should be banned in cars until its sorted . same as any overbright light that dazzles road users .
    well thats my view on the matter .
      Yeah incandescent bulbs will run quite hot, depending on wattage and physical dissipation size. All of the heat must be dissipated, they can't get infinitely hot. Just that LEDs will melt down before tungsten.
      I don't think I can hold onto 80°C. 60°C probably is my absolute limit. I burned myself trying to remove a bulb cover in my car trying to investigate what kind of lamp it uses, I think it got to 70°C+ and it seems to only be 0.5W? I might have to remove it or replace it with LEDs just so I can leave my doors open without fear of draining the battery - seems it draws 3A - same as a headlight bulb - when the lights are on.
      Not replacing them with this bulb of course, I think that bulb was only 0.5W to 1W at most. Perhaps an override switch to shut the lamps off when I don't want them on is a better solution...
        I have a truck that has this crap that there is no way to turn off the inside cab light it just times out for some reason now it does not time out anymore so I took out the fuse for it and be done with it
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          Originally posted by eccerr0r View Post
          Aren't yellow lamps frequently used for fog lights too?
          only in france
