Best 1.8V Eprom Programmer?
    Hi guys, I already have a TLL866CS and it has proved a very good tool, I love it and find the software very easy to use but it does not program 1.8V chips.
    I know there is a 1.8V adapter for the TL866
    https://es.aliexpress.com/item/10050...46588439%22%7D
    But if I get one of these do I need to install a different version software to add all the 1.8V Eprom types to the IC database?
    Is there something else better for 1.8V Eprom rather than using this adapter wit hthe TL866, or some other advantage to gain if I get a second Eprom programmer to add to my tool box, that can handle 1.8V and maybe other things the TL866 can't do? Even if it costs a bit more.
    I'm specifically interested in programming GPU BIOS chips.
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    Re: Best 1.8V Eprom Programmer?
    i would say upgrade to the new 866II+ - it goes down to 1.8v and the software is upgraded almost weekly.
    and buy the BLACK SOCKET version.
    features
    http://www.xgecu.com/EN/TL866_main.html
    shop
    https://www.aliexpress.com/item/32992209964.html
    software
    http://forums.xgecu.com/viewthread.php?tid=20
    and - a library here that lets you run it with Linux - it does work
    https://github.com/radiomanV/TL866
      features
      shop
      software
      Rather than get a 1.8V adapter for my TL866CS? Is that due to better software support for the 866II+?
        Have you considered the SVOD3 programmer at all? Apart from doing EC's, I use it for all my SPI chips and it's switchable to 1.8V from within the software. If there isn't a chip supported, you can request for it via the app.
          yes, the other programmers have not had an update for a long time and never will.
          they got dumped after they got cloned to death!
            Sofi SP16-B is a good programmer and support 1.8v, updates montly. you can get it aliexpress
