TOP201YAI 3-Terminal TO-220 PWM switch Figure #7 in date sheet
    I would like to know what the specifications for the transformer in this data sheet is I would like to build one
    Also for figure number 8 as well
    Also for figure number 9 as well
    Here is the data sheet I know that this item has been disconnected but I can buy them surplus
    https://cdn.badcaps-static.com/pdfs/...da43fe7f6c.pdf
    I have a mad scientist streak in me lately and want to be a little adventurous
    The reason is I have some ATX switching power supply that I have as spare parts from and wondering if I could use one for this purpose
    Or just use the standby circuit that is for this purpose but then I would have to reengineer the circuit to be able to use just this part of it
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
