Thread Tools | Display Modes |
#1 |
City & State: Worthing
My Country: uk
I'm a: Knowledge Seeker
![]() Hi guys,
I have a JVC LT-40C860 stuck on logo. I have tried all sorts of resets but nothing seems to help. I have checked the fuses on the main board and power supply and capacitors everything seems ok. From what i was reading on the forum I tend to believe it's a firmware problem. Now the question, is anyone who can give me the firmware so that i can put it on a usb drive and see if it solves my problem ? Tried contacting JVC but i got no reply. I've attached some pictures with the boards in case anyone wants any extra info. Thank you, |
#2 |
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
![]() Is U13 an MX25L512 EEPROM or equivalent. If so I would freeze it with freezer spray and make cerain it gets really cold (set powered off) and then attempt to reboot the TV. You may have a failing EEPROM
__________________
Willing to help but I'm no expert. |
#3 |
My Country: uk
![]() It is KH25L1606E. I'm just going to buy a spray and I'll give it a go
#4 |
My Country: uk
![]() I have frozen the EEPROM and it went over the logo but got reseted in a few seconds.
#5 |
City & State: Nuneaton Warwickshire
My Country: uk
![]() if you cant find a firmware dump this maybe be your board maybe worth sending the seller a lower price offer
https://www.ebay.co.uk/itm/234098833...EAAOSwpL5g-Jxy Last edited by vinceroger69; 08-09-2021 at 09:58 AM.. |
#6 |
My Country: Wales
![]() Try freezing it again and allow the EEPROM to get really cold. Give it several good blasts. Very often the inside of the IC hasn't become cold enough.
#7 |
My Country: uk
#8 |
City & State: Free State
My Country: South Africa
Line Voltage: 220V AC
I'm a: Professional Tech
![]() I saved a tv like that. I desoldered the chip off the board and fit it in my eprom reader. Then i sprayed it ice cold and started the read process. During the read i sprayed it again. I got a data image. Saved it, and dumped it into a new blank chip and viola. It worked , tv went out back to customer, fixed.
#9 |
My Country: uk
![]() Unfortunately the freezing didn't work for me and i don't think it's worth me buying a eeprom reader. I was looking for a firmware to use with an USB drive but no one seems to have one . I'm thinking on getting another main board.
#10 |
City & State: Diyarbakir
My Country: Turkiye
Line Voltage: 220VAC 50Hz
![]() try this : https://yadi.sk/d/_zlpfQXu5tD28w
__________________
Genç Elektronik ve Bilgisayar |
#11 |
My Country: Wales
![]() The EEPROM reader/writer is dead cheap and worth having in your tool box.
#12 | |
My Country: uk
![]() Quote:
I have tried with this file but nothing happens, doesn't start updating |
#13 | |
My Country: uk
![]() Quote:
#14 |
My Country: uk
![]() Hi guys,
I have ordered an eeprom reader/writer but i couldnt get a working driver to be able to access the info on the eeprom so I bought a replacement main board and got it in. Tv is working perfect now. If any of you has a reliable software for win10 that i can use with the eeprom reader/writer please share'it with me ! Regards, |
#15 |
My Country: Wales
![]() Which EEPROM reader/writer did you buy?
If it was the CH341A then here are a few progs that should work. Last edited by dick_barton; 08-20-2021 at 04:32 AM.. |
#16 |
City & State: Sochi
My Country: russia
![]() Here is another program for CH341A.
#17 |
My Country: uk
Thread Tools | |
Display Modes | |
