Hi gents,
so i recovered a liquide damaged GPU (MSI 1070 Gaaming X) i try to fix it,
the corrosion is so bad that it ate some component's pads.
some are easy identifiable, others are not, from a similaire Boardview (Msi 1080GTX attached) I got some info:
1-in boardview the component is named SOT23-5 no other info:
from the pic we can see marking L1C9.
no datasheet available and I cant find where to purchase it, What other Ref can I use instead.
2-not available in the boardview but i guess its Sot23 (marking 2A. and N symbole)
same no datasheet no info where to get it or something similaire.
you can see in the pic also the component L1117LG which i found it easily in aliexpress.
3- in boardview the componant is named 0.807v a quick googling gave me Sot23-8 :
marking ADPG also no info where to get it.
so any idea with what component i can use instead ?
the MSI 1080 boardveiw
PS: a high res of the PCB pic
