the computer freezes up with the i7-4790k cpu installed but it works fine with a lower end processor. would delidding fix this issue?
i7-4790k makes the computer freeze up during startup
Re: i7-4790k makes the computer freeze up during startup
Originally posted by kjchatman View Postthe computer freezes up with the i7-4790k cpu installed but it works fine with a lower end processor. would delidding fix this issue?
A CPU delid is only useful if you are trying to lower CPU temps with at least watercooling.
The purpose of a delid is to remove some of the thermal barrier (aka thickness of the TIM and sealant) to have better mating between the IHS and the die.
The fact it freezes (not enough info here) says it's likely not thermal related.
Originally posted by kjchatman View Postit ran for 8 years and then the customer unplugged the water pump for some reason. I ran it for hours without realizing that the pump was not running. I figure the TIM is dried up
Unless they disabled the OTP it would have shutdown or at minimum throttled before killing the CPU.
That said when it freezes, is that under any load or just idle on desktop?
What are the temps?
Chances are the CPU is bad but test properly first.
it never makes it to the desktop unless the graphics card is removed and the intel hd graphics is used instead. you also have to disable the intel hd graphics driver and then it doesn't freeze. the system works perfectly with the other cpu
seems to have a faulty processor...
https://www.intel.com/content/www/us...rocessors.html
