Hi, can someone help me I have determine voltage on this cap on picture below. I have donor board and I would like to replace caps but I am not sure if they are same voltage. I see that they are both 270 ohm, but on this other one there is no voltage I google that C letter is for 16V mark, but I would like someone to confirm if thats true. And Would it be wise if we determine they are 16V to replace them all ? btw I know that one cap is missing and I noticed that on one board those 270 ohm caps are a bit shorter.
Can't recognized caps
Re: Can't recognized caps
The cap has a rating of 270uF (not ohms, that is resistors).
As for voltage ratings, depends what part of the circuit it is located...
The pic on the left, shows a 6.3v cap on the left of the heat spreader and a 2.5v cap on the right of it.
I would think a 6.3v cap would be fine.
However having the correct cap for a replacement would be ideal.
Also voltage ratings on caps are generally the MAX voltage the cap is rated for, so using a 16v cap on a 6.3v circuit should be fine.
Sorry I wrote wrong I ment uF not ohms don't know what I was thinking...
Ones on the left would replace those to the right. I forgot to say that left is donor board, and on the right is board I would like to repair.
6.3V are caps beside that one I would take off, but not that I pointed red on the picture.
Originally posted by gt403cyl View PostI would think a 6.3v cap would be fine.
This is input decoupling of the CPU VCore VRM so this will obviously be rated at 16V at least. Put a 6.3V and you'll get some nice fireworks…Last edited by piernov; 03-30-2022, 10:14 AM.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Originally posted by piernov View PostThis is input decoupling of the CPU VCore VRM so this will obviously be rated at 16V at least. Put a 6.3V and you'll get some nice fireworks…
I found board schematics for donor board and those caps are 16V, I guess that would be okay to replace all on that board I want to revive, right ?Last edited by Thermaltake; 03-30-2022, 11:16 AM.
Originally posted by piernov View PostThis is input decoupling of the CPU VCore VRM so this will obviously be rated at 16V at least. Put a 6.3V and you'll get some nice fireworks…Originally posted by Thermaltake View PostI know when people are talking rubbish don't worry
Can you tell me if it's not a problem if those are 16V I found in manual of nippon caps that C is for 16V, but I'm not sure I need someone who is in electronics to confirm.
If you would read my response you would see that. I even state that.
Originally posted by lotas View PostYes, replace all three, just observe the polarity of the capacitor on the board (ASUS has a non-standard polarity - with a white stripe it is positive).
For all info. As I see they both have negative polarity on the same side Asrock and Asus. White is negative.Last edited by Thermaltake; 03-30-2022, 10:58 PM.
