RTX 2080 11GB after memory replace, now many small errors on all chips
    I have this MSI RTX 2080 11GB, that after memory replace works for hour. after that i have many small errors on all chips randomly and card crash under memory load.
    when i heat card with low resolution furmark, ater minute i can switch to hi res test and it work ok. when power off pc for few minutes, card crash under hi res test gain
    Re: RTX 2080 11GB after memory replace, now many small errors on all chips
    Might be bad solder joint on gpu core itself
