latitude 5420 computrace
    hello im having dell latitude with computrace looking for help here please find attach dumb latitude 5420
    Re: latitude 5420 computrace
    share service tag number
      91T2ZD3-8FC8 i need to unlock this bios password
        Hi, i have an Dell Latitude 5420 Service Tag 1MSQ3M3-8FC8, please help me to remove password, thank you.
        all donations are welcome,
          There is no free password generator for 8FC8 suffix, so your only option is to dump your bios and upload the file here for unlocking.
          Become a Badcaps supporter
          Thanks to all supporters.
            Please i need to unlock dell 5420 bios
              1.06 MB is not a good read at all. Try again, and be more careful this time.
              https://www.badcaps.net/forum/showpo...8&postcount=52
                Try this sir
                  Did you solve the problem, or you need help?
                    Originally posted by vesko356 View Post
                    did you solve the problem, or you need help?
                    i need help because in reality i got 32mb file but when i compressed it it's as you see sir
                      Try this sir
                      it's even worse now!
                      Did you read this:
                      Originally posted by Vesko356 View Post
                      The safest method for verifying the contents is to read the chip after programming and compare the resulting file with the source. This eliminates any doubt, and you can proceed to soldering the chip to the board.
                      In this way, each step of the process is verified, and in the event of a problem, only the last step can be checked - namely the soldering to be inspected.
                      Otherwise, everything has to be done again from the beginning, because it is not certain at what stage the mistake was made.
                      This also applies to the initial reading of the chip with the original (containing the password) dump. Two or three content dumps need to be made that are compared to each other. If they are the same then it is certain that the content has been read correctly.
                      The procedures described above can take five minutes longer, but save five hours of headaches.
                        My question was not to you, but to @lavie. I have already answered you.
                        ...but when i compressed it it's as you see sir
                        Because you have a 32MB file full of zeros or FF it's still the same. When you compress/archive it, it becomes small because it does not contain information.
                          i lost the original dump sir you were right what to do i don't know
                            What do you mean? Did you erase the content or what?
                              yes i did sir
                                Hi guys need help remove password and computrace for Dell Ltitude 5420, I have attached file, Thanks in advance
                                  Hello guys, can someone help me clear password and computrace on dell 5420 LA-K491P rev. 2.0
                                    1st boot press F2, write Service Tag, disable Absolute, save, restart, 2nd boot press alt+F to exit factory mode.
                                      Please help me clear password & computrace Dell 5420 11th intel cpu, serv tag 476BNN3
                                        Bump, can anyone help me ?
