Hi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage drops to ~0.1V (if I remember correctly). I can go up to 6-7 amps but nothing gets hot at least not in a way I can feel it with my hand/fingers or can see it with ipa.
Obviously taking into consideration Ohm's law this is expected.
I suspect I killed these cards a long time ago by applying a lot of current (if they were not dead before) nevertheless I don't want to make the same mistake in the future.
So I tried measuring the resistance at different points on that rail but my multimeter only shows four digits in ohms mode. The lowest on the rail was 00.21 ohm but that's the resistance of the leads...
I tried measuring voltage at different points (while injecting voltage), I can measure 4 digits in millivolts but that didn't show me anything meaningful (or I'm just stupid).
So what do you suggest? I've seen a Northridgefix video in which the guy pinpointed the location of the short on a dead shorted board with a Flir cam, the heat spot (mosfet) was barely noticable on the cam (only a few degree difference vs the board) so even with a Flir cam it's not easy but I don't have a Flir cam.
How do you deal with this situation?
Thank you in advance.
