Hello, some components have been burned in my graphics card, but I don't know exactly what they are, they are from LB16 to LB19, the description of the boarview is "220/8/3A/S", I would appreciate if someone could tell me which component I should buy and its value. All the best
Gigabyte GTX 1080 mini
Re: Gigabyte GTX 1080 mini
Possibly 220nH probably doesn't make a lot of difference they are only 12v input filtering, a piece of wire will do until you can ascertain the board is fixable.
The real question is why are they blown? Most probably a shorted output stage U525-U528 failing a visual inspection to identify the faulty drmos, you can measure GH pin 6 on them in resistance mode, the shorted one will probably have a shorted gate also, maybe also check GL pin 36
The U525 was shorted, I have already removed it, for now there is no short on any of the inputs when . What I needed to know is if the LBs were resistors or inductors, so you tell me they are 220nh inductors, I will buy the components and see if it works when I have everything soldered, thanks
