Hello to everyone, I've bought a not working Powercolor RX580 8GB to try to fix it; Immediately with a multimeter I've seen that on 12Vdc that we can found 8pin and 6pin connectors there is only 700Ohm between the 12Vdc power line and GND; also someone has tried to rework the board, I've seen both mosfet 4C05N are in short circuit between drain and source (bad soldering work I can say, see image).
I'll try remove the mosfets to see if the low isolation disappear, does anyone have this board? can you tell which mosfet do you have mounted? do you have some schematics? do you have a board view with the exact position of every main components?
I'll appreciate every contribute
