I have an ASUS P6X58D Premium motherboard that is not posting and gives no display.
First I thought that it was corrupted bios so I flashed the latest bios using an external programmer. Still nothing. So I thought that the bios chip is faulty. Used a different chip still the same result and used the original chip in a different motherboard and it worked, so its not the chip.
CPU and RAM are known working (tested on 2 motherboards). No bent pins in socket.
What I noticed is that the MemOK light stays on and according to the manual its some sort of compatibility issues with the RAM and bios version. However, I flashed the latest bios and the RAM Im using is in the QVL.
I've read that this is a common issue but I haven't found the solution yet.
I've tried pressing the MemOK button just as what is said in the manual and it cycles through the tests (different blinking speeds) until it comes to the point where it stays on again and still no post.
Any help is much appreciated. Thanks.
